Introduzione
If your laptop is displaying the dreaded ‘blue screen of death,’ randomly reboots itself, and/or frequently freezes, you will need to replace the Random Access Memory (RAM) on your laptop. You may also want to upgrade your RAM for more memory. Follow this guide in order to replace or upgrade your RAM.
Remember to power off your laptop and unplug it from the power adapter prior to beginning this repair.
Cosa ti serve
Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
Position the flat end of the Spudger under one of the corners on the RAM cover and pry it up slightly.
Move the spudger around the periphery of the cover to lift the cover up.
