Introduzione
Is your Asus Q525U laptop unable to hold a charge or power up without being connected to a charging cord? Follow this guide if you need to replace the battery of your Asus Q525U.
Before beginning this guide, be sure to turn off your laptop and disconnect from the power adapter.
Cosa ti serve
Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
The battery of the device is outlined in red.
Using a Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery in place.
