Salta al contenuto principale
Asus Q504UA-BHI5T13 Speaker Replacement
Cosa ti serve
  1. Asus Q504UA-BHI5T13 Speaker Replacement, Back Panel: passo 1, immagine 1 di 1
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Speaker Replacement: passo 2, immagine 1 di 1
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Speaker Replacement: passo 4, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Speaker Replacement: passo 5, immagine 1 di 1
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Speaker Replacement, Battery: passo 6, immagine 1 di 1
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
  7. Asus Q504UA-BHI5T13 Speaker Replacement: passo 7, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the five 4mm screws around the battery.
  8. Asus Q504UA-BHI5T13 Speaker Replacement: passo 8, immagine 1 di 2 Asus Q504UA-BHI5T13 Speaker Replacement: passo 8, immagine 2 di 2
    • Use the small plastic opening tool to remove the ZIF Connector on the right side of the battery.
  9. Asus Q504UA-BHI5T13 Speaker Replacement: passo 9, immagine 1 di 2 Asus Q504UA-BHI5T13 Speaker Replacement: passo 9, immagine 2 di 2
    • Remove the battery from the device.
  10. Asus Q504UA-BHI5T13 Speaker Replacement, Speaker: passo 10, immagine 1 di 1
    • We will start with the left speaker. The left speaker is the one with the letter ā€œLā€ on it. Use the Phillips #0 screwdriver to remove the two 4mm screws around the left speaker.
    • It shares the bottom screw with the battery.
    • This is the screw that is shared with the battery. This screw will be removed once the battery is removed.
  11. Asus Q504UA-BHI5T13 Speaker Replacement: passo 11, immagine 1 di 2 Asus Q504UA-BHI5T13 Speaker Replacement: passo 11, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to pull the plug towards the speaker.
    • Take care when removing the cable. Damaging the cable will stop the part from working.
  12. Asus Q504UA-BHI5T13 Speaker Replacement: passo 12, immagine 1 di 2 Asus Q504UA-BHI5T13 Speaker Replacement: passo 12, immagine 2 di 2
    • Unhook the red and black twisted wire from the tabs that are between the two speakers. This prevents damage to the wires as the speakers are removed.
    • Remove the Left (L) speaker.
  13. Asus Q504UA-BHI5T13 Speaker Replacement: passo 13, immagine 1 di 1
    • Now for the right speaker, use the Phillips #0 screwdriver to remove the two 4mm screws around the speaker.
    • It shares the bottom screw with the motherboard.
    • This screw is shared with the mother board, this screw will need to be removed however the mother board does not need to be removed before the speaker.
  14. Asus Q504UA-BHI5T13 Speaker Replacement: passo 14, immagine 1 di 1
    • Remove the Right (R) speaker from the device. Using a spudger helps to slide it out.
Conclusione
Joel Joly
Membro da: 10/02/17
129 Reputazione
1 Guida realizzata
USF Tampa, Team S10-G4, Thompson Fall 2017 Membro di USF Tampa, Team S10-G4, Thompson Fall 2017
USFT-THOMPSON-F17S10G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 300
