Salta al contenuto principale
Asus Q502LA-BSI5T14 RAM Replacement
Cosa ti serve
  1. Asus Q502LA-BSI5T14 RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Ensure your device is powered off before starting
    • Flip the laptop so the back panel is facing up.
    • Remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 RAM Replacement: passo 2, immagine 1 di 1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 RAM Replacement: passo 3, immagine 1 di 3 Asus Q502LA-BSI5T14 RAM Replacement: passo 3, immagine 2 di 3 Asus Q502LA-BSI5T14 RAM Replacement: passo 3, immagine 3 di 3
    • The RAM is the rectangular plate in the center.
    • Use a spudger to press the clips securing the RAM outward. The RAM will pop up enabling you to lift it out.
Conclusione
Mary Kounelas
Membro da: 09/25/17
715 Reputazione
5 Guide realizzate
USF Tampa, Team S4-G1, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S4G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 22
Tutti i Tempi: 580
