Salta al contenuto principale
Asus Q502LA-BSI5T14 Motherboard Replacement
Cosa ti serve
  1. Asus Q502LA-BSI5T14 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Motherboard Replacement: passo 2, immagine 1 di 1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Motherboard Replacement: passo 3, immagine 1 di 2 Asus Q502LA-BSI5T14 Motherboard Replacement: passo 3, immagine 2 di 2
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Motherboard Replacement: passo 4, immagine 1 di 2 Asus Q502LA-BSI5T14 Motherboard Replacement: passo 4, immagine 2 di 2
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
  5. Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 2 Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: passo 5, immagine 2 di 2
    • Remove the four ribbons connected to the motherboard.
  6. Asus Q502LA-BSI5T14 Motherboard Replacement: passo 6, immagine 1 di 2 Asus Q502LA-BSI5T14 Motherboard Replacement: passo 6, immagine 2 di 2
    • Disconnect the five wires attached to the motherboard by pulling gently. There are three thin wires in the upper left corner.
  7. Asus Q502LA-BSI5T14 Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the two 5 mm Phillips #1 screws attaching the stabilizer to the motherboard
  8. Asus Q502LA-BSI5T14 Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the four 5 mm Phillips #1 screws around the perimeter of the motherboard.
  9. Asus Q502LA-BSI5T14 Motherboard Replacement: passo 9, immagine 1 di 2 Asus Q502LA-BSI5T14 Motherboard Replacement: passo 9, immagine 2 di 2
    • Remove the six 5 mm Phillips #1 screws securing the silver plates to the motherboard.
    • Open the laptop approximately 1/2" to loosen the hinge and release the motherboard.
  10. Asus Q502LA-BSI5T14 Motherboard Replacement: passo 10, immagine 1 di 1
    • Gently lift the motherboard out and away from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
Mary Kounelas
Membro da: 09/25/17
715 Reputazione
5 Guide realizzate
USF Tampa, Team S4-G1, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S4G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,628
