Salta al contenuto principale
Asus Q502LA-BSI5T14 Fan Replacement
Cosa ti serve
  1. Asus Q502LA-BSI5T14 Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Make sure your device is powered off before you begin.
    • Flip the laptop over and remove the ten 11 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Fan Replacement: passo 2, immagine 1 di 1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Fan Replacement: passo 3, immagine 1 di 1
    • Remove the eight 5 mm Phillips #1 screws securing the fan and copper piece to the motherboard.
    • Remove the wires by gently pulling them out.
  4. Asus Q502LA-BSI5T14 Fan Replacement: passo 4, immagine 1 di 1
    • Gently lift the fan up and away from the laptop.
Conclusione
Mary Kounelas
Membro da: 09/25/17
715 Reputazione
5 Guide realizzate
USF Tampa, Team S4-G1, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S4G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 371
