Salta al contenuto principale
Asus Q500A Hard Drive Replacement
Cosa ti serve
  1. Asus Q500A Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip device onto backside
  2. Asus Q500A Hard Drive Replacement: passo 2, immagine 1 di 1
    • Use a J0 screwdriver bit to remove both screws on the back-plate, found at the bottom of device.
    • Remove back-plate.
    • Note: Use prying tool if your having issues lifting back-plate.
  3. Asus Q500A Hard Drive Replacement: passo 3, immagine 1 di 2 Asus Q500A Hard Drive Replacement: passo 3, immagine 2 di 2
    • Remove 4 screws from the metal hard-drive case. There will be one in each corner.
    • Remove the hard-drive case from the device.
  4. Asus Q500A Hard Drive Replacement: passo 4, immagine 1 di 1
    • Remove the hard-drive. It will be connected to the integrated sata-port in the device.
    • Place hard-drive into slot and connect to the integrated sata port.
    • Place hard drive case back on top of the new hard-drive.
    • Screw in the four screws on the hard-drive case.
  5. Asus Q500A Hard Drive Replacement: passo 6, immagine 1 di 1
    • Place back-plate back on device.
    • Screw in the 2 screws on the back of the plate.
Conclusione
Altre 2 persone hanno completato questa guida.
cameron
Membro da: 02/15/17
319 Reputazione
3 Guide realizzate
USF Tampa, Team 12-5, Eyestone Spring 2017 Membro di USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 969
