Salta al contenuto principale
Asus Q500A Battery Replacement
  1. Asus Q500A Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip device onto backside.
  2. Asus Q500A Battery Replacement: passo 2, immagine 1 di 1
    • Locate the two sliding locks.
    • Slide the sliding lock 1 to the right to unlock it .
    • There should be a red marker to indicate that it is unlocked. This lock will stay unlocked until slid back into the locked position.
  3. Asus Q500A Battery Replacement: passo 3, immagine 1 di 1
    • Slide the sliding lock 2 to the left to unlock it.
    • There will not be any indicator that it is unlocked. This lock will relock if you do not continue to push it to the left.
  4. Asus Q500A Battery Replacement: passo 4, immagine 1 di 1
    • While the first and second lock are unlocked, slide the battery out to remove it.
    • When reinserting the replacement battery, make sure to slide sliding lock 1 back into the locked position. Otherwise the battery may come loose.
Conclusione
cameron
Membro da: 02/15/17
319 Reputazione
3 Guide realizzate
USF Tampa, Team 12-5, Eyestone Spring 2017 Membro di USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 497
