Cosa ti serve
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Remove ten Phillips #0 screws that secure the plastic bottom cover to the chassis.
Six 9.6 mm screws
Four 4.6 mm screws
Push metal bracket away from battery connector.
Use a spudger to push the battery connection straight up.
If you pull the without moving that metal bracket, you could damage the connections on the motherboard and likely rip a few solder pads. It almost happened to me when creating this guide.
Remove the Phillips #0 screws that secure the battery to the lower case assembly
Three 4.7 mm screws.
Disconnect the Wifi/Bluetooth RF cables from the wireless card.
Pull straight up to disconnect the SATA combo cable from the motherboard.
Use a spudger to flip up the retaining flap on the ribbon cable ZIP socket.
Use tweezers pull the ribbon cable out of the ZIF socket.
Can you identify what this connector runs to? I am looking for the connector for the backlight.
Pull up on the corner of the motherboard and remove from the laptop.
**I am not responsible for any damages caused by any attempts at this repair. Use at your own risk.
Altre 5 persone hanno completato questa guida.
3 Commenti
Where is the CMOS battery located? For the life of me I can’t find it.
Ne meither and Asus didn’t know, either. IDK, my laptop wouldn’t hold BIOS settings or Time/Date. Asus told me it was a coin style CMOS battery on the back side of the motherboard. Called them back to report not finding it and then they refused to help because they accused me of intent to modify the unit, which they do not support. They suggested I send it to a service center on the east coast (I’m on the left coast) with an open limit on repair. All this for a laptop which has been out of warranty for 3 years. Eventually one tech suggested it might be built into the main battery but couldn’t say for sure.
Next time I will buy a Dell, Acer, HP or some other brand.
This laptop mother board does not have the usual CMOS/RTC coin cell battery. Apparently the settings (BIOS/UEFI) are maintained by the laptop battery itself. When I disconnected the laptop battery, the date/time reverts to the original factory date/time. HOWEVER .. there is a cable that contains the LCD connector, the SATA HDD connector based on that some indicate it is a “CMOS cable” which in all the years I’ve been working on computers, have never heard of. That is the same with all MacBook Pro laptops - no CMOS battery — it uses the laptop battery and NOT a CMOS coin cell battery.
