Salta al contenuto principale
Asus Q302UA-BHI5T20 Motherboard Replacement
Cosa ti serve
  1. Asus Q302UA-BHI5T20 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Asus Q302UA-BHI5T20 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Place laptop upside down.
    • Use a Phillips #0 screwdriver to remove the ten 1 cm case screws from the bottom of the laptop.
  2. Asus Q302UA-BHI5T20 Motherboard Replacement: passo 2, immagine 1 di 2 Asus Q302UA-BHI5T20 Motherboard Replacement: passo 2, immagine 2 di 2
    • Disconnect the CPU fan by carefully pulling out the small black connector(plug) located in the corner (redbox)
    • Use a Phillips #0 screwdriver to remove the three 4 mm screws that secure the fan.
  3. Asus Q302UA-BHI5T20 Motherboard Replacement: passo 3, immagine 1 di 2 Asus Q302UA-BHI5T20 Motherboard Replacement: passo 3, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the four 3 mm screws that secure the heat sink.
  4. Asus Q302UA-BHI5T20 Motherboard Replacement: passo 4, immagine 1 di 2 Asus Q302UA-BHI5T20 Motherboard Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #0 screwdriver to unscrew the five 5 mm screws that secure the battery.
    • Disconnect the battery's bundled cable connector and lift the battery up and out of the laptop.
  5. Asus Q302UA-BHI5T20 Motherboard Replacement: passo 5, immagine 1 di 1
    • Disconnect the WiFi antennae by gently pulling up at each antenna's connector. Use a spudger to help lift each antenna free from the WiFi card if needed.
  6. Asus Q302UA-BHI5T20 Motherboard Replacement: passo 6, immagine 1 di 1
    • Speaker Data Connector.
    • Gently pry out.
  7. Asus Q302UA-BHI5T20 Motherboard Replacement: passo 7, immagine 1 di 1
    • Pull up the ZIF connector tabs and then pull out the ribbon cables.
    • For the orange boxes, you pull the little black tab up to remove connector.
    • A little extra force might need to be used for this step.
  8. Asus Q302UA-BHI5T20 Motherboard Replacement: passo 8, immagine 1 di 1
    • Display Connector.
    • Pull tab, and pull up.
  9. Asus Q302UA-BHI5T20 Motherboard Replacement: passo 9, immagine 1 di 2 Asus Q302UA-BHI5T20 Motherboard Replacement: passo 9, immagine 2 di 2
    • Unscrew the two 6 mm screws.
    • After removing the screws, lift the hinge up slightly to give clearance to the motherboard.
    • Some force is required to lift the metal hinge support up. To lift, pull up and rotate as you're pulling up.
  10. Asus Q302UA-BHI5T20 Motherboard Replacement: passo 10, immagine 1 di 2 Asus Q302UA-BHI5T20 Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove the six 4 mm screws.
    • Gently pick up the motherboard without applying any unnecessary force.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 506
