Salta al contenuto principale
Asus Q200E-CT144H Speaker Replacement
Cosa ti serve
  1. Asus Q200E-CT144H Speaker Replacement, Back Cover: passo 1, immagine 1 di 1
    • To start, turn off the laptop and disconnect the power cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Flip the laptop over so the back panel is visible.
  2. Asus Q200E-CT144H Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the 9 screws holding the cover in place by taking a Phillips #00 Screwdriver and turning it counterclockwise.
  3. Asus Q200E-CT144H Speaker Replacement: passo 3, immagine 1 di 2 Asus Q200E-CT144H Speaker Replacement: passo 3, immagine 2 di 2
    • Use an iFixit opening tool to lift the back cover and remove it from the laptop.
  4. Asus Q200E-CT144H Speaker Replacement, Battery: passo 4, immagine 1 di 2 Asus Q200E-CT144H Speaker Replacement, Battery: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the battery connector by using tweezers to lift up on it.
  5. Asus Q200E-CT144H Speaker Replacement: passo 5, immagine 1 di 2 Asus Q200E-CT144H Speaker Replacement: passo 5, immagine 2 di 2
    • Remove the nine Phillips #00 screws that hold the battery in place.
    • There is one 9.2mm screw, four 4.7mm screws, and four 5.7mm screws.
  6. Asus Q200E-CT144H Speaker Replacement: passo 6, immagine 1 di 2 Asus Q200E-CT144H Speaker Replacement: passo 6, immagine 2 di 2
    • Remove the battery from the battery bay.
  7. Asus Q200E-CT144H Speaker Replacement, Speaker: passo 7, immagine 1 di 1
    Compra
    • Use tweezers to disconnect the speaker's main power connectors.
  8. Asus Q200E-CT144H Speaker Replacement: passo 8, immagine 1 di 2 Asus Q200E-CT144H Speaker Replacement: passo 8, immagine 2 di 2
    • Use a metal spudger to pry the speaker housing from the laptop.
    • There will be glue holding the speaker housing to the laptop.
  9. Asus Q200E-CT144H Speaker Replacement: passo 9, immagine 1 di 2 Asus Q200E-CT144H Speaker Replacement: passo 9, immagine 2 di 2
    • Remove the right speaker from its housing.
    • Use tweezers to remove the black and white wire from its groove.
    • The black and white wire connects the speaker housings together.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 129
