Salta al contenuto principale
Asus Q200E-CT144H Back Cover Replacement
Cosa ti serve
  1. Asus Q200E-CT144H Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • To start, turn off the laptop and disconnect the power cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Flip the laptop over so the back panel is visible.
  2. Asus Q200E-CT144H Back Cover Replacement: passo 2, immagine 1 di 1
    • Remove the 9 screws holding the cover in place by taking a Phillips #00 Screwdriver and turning it counterclockwise.
  3. Asus Q200E-CT144H Back Cover Replacement: passo 3, immagine 1 di 2 Asus Q200E-CT144H Back Cover Replacement: passo 3, immagine 2 di 2
    • Use an iFixit opening tool to lift the back cover and remove it from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 135
