Salta al contenuto principale
Asus Padfone X Mini Screen Replacement
Cosa ti serve
  1. Asus Padfone X Mini Screen Replacement, Speaker: passo 1, immagine 1 di 1
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
    • This is not the cover with the speaker attached.
  2. Asus Padfone X Mini Screen Replacement: passo 2, immagine 1 di 1
    • Lift the battery out from the top of the device.
  3. Asus Padfone X Mini Screen Replacement: passo 3, immagine 1 di 1
    • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
    • Remove the cover.
  4. Asus Padfone X Mini Screen Replacement: passo 4, immagine 1 di 1
    • Turn the cover over.
    • The speaker is attached to the inside of the cover and to the right of the camera hole.
  5. Asus Padfone X Mini Screen Replacement: passo 5, immagine 1 di 1
    • Remove speaker with standard tweezers to minimize damage, and replace.
  6. Asus Padfone X Mini Screen Replacement, Screen: passo 6, immagine 1 di 1
    • Detach the black connector on the left hand side of the motherboard.
    • Don't completely remove the black connector.
  7. Asus Padfone X Mini Screen Replacement: passo 7, immagine 1 di 1
    • Disconnect silver connector from the motherboard. It is located on the left hand side above the black connector.
  8. Asus Padfone X Mini Screen Replacement: passo 8, immagine 1 di 2 Asus Padfone X Mini Screen Replacement: passo 8, immagine 2 di 2
    • Remove motherboard and replace screen.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 259
