Salta al contenuto principale
Asus Padfone X Mini Camera Replacement
Cosa ti serve
  1. Asus Padfone X Mini Camera Replacement, Speaker: passo 1, immagine 1 di 1
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
    • This is not the cover with the speaker attached.
  2. Asus Padfone X Mini Camera Replacement: passo 2, immagine 1 di 1
    • Lift the battery out from the top of the device.
  3. Asus Padfone X Mini Camera Replacement: passo 3, immagine 1 di 1
    • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
    • Remove the cover.
  4. Asus Padfone X Mini Camera Replacement: passo 4, immagine 1 di 1
    • Turn the cover over.
    • The speaker is attached to the inside of the cover and to the right of the camera hole.
  5. Asus Padfone X Mini Camera Replacement: passo 5, immagine 1 di 1
    • Remove speaker with standard tweezers to minimize damage, and replace.
  6. Asus Padfone X Mini Camera Replacement, Screen: passo 6, immagine 1 di 1
    • Detach the black connector on the left hand side of the motherboard.
    • Don't completely remove the black connector.
  7. Asus Padfone X Mini Camera Replacement: passo 7, immagine 1 di 1
    • Disconnect silver connector from the motherboard. It is located on the left hand side above the black connector.
  8. Asus Padfone X Mini Camera Replacement: passo 8, immagine 1 di 2 Asus Padfone X Mini Camera Replacement: passo 8, immagine 2 di 2
    • Remove motherboard and replace screen.
  9. Asus Padfone X Mini Camera Replacement, Camera: passo 9, immagine 1 di 1
    • Turn over the motherboard.
  10. Asus Padfone X Mini Camera Replacement: passo 10, immagine 1 di 1
    • Using tweezers pull out the connector that connects the camera to the motherboard.
  11. Asus Padfone X Mini Camera Replacement: passo 11, immagine 1 di 2 Asus Padfone X Mini Camera Replacement: passo 11, immagine 2 di 2
    • Take out the camera.
    • Put in the new camera by sliding the camera connector into the receiver.
Conclusione
James Jackson
Membro da: 09/18/18
97 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 177
