Cosa ti serve
Use plastic opening tool to pry off the back cover of the phone.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Remove the warning sticker that covers the battery plug and connecting cord.
Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
Disconnect battery connecting cord using tweezers.
Altre 6 persone hanno completato questa guida.
Un commento
Pull the battery connector towards USB. You will break it if you pull it up, as I did.
I wouldn’t recommend metal tweezers as it could shortcut the battery.
