Salta al contenuto principale
Asus Padfone 2 Battery Replacement
Cosa ti serve
  1. Asus Padfone 2 Battery Replacement, Power off phone: passo 1, immagine 1 di 1
    • Hold down power button to shut off phone.
  2. Asus Padfone 2 Battery Replacement, Remove back cover of phone: passo 2, immagine 1 di 2 Asus Padfone 2 Battery Replacement, Remove back cover of phone: passo 2, immagine 2 di 2
    • Use plastic opening tool to pry off the back cover of the phone.
  3. Asus Padfone 2 Battery Replacement, Battery Removal: passo 3, immagine 1 di 3 Asus Padfone 2 Battery Replacement, Battery Removal: passo 3, immagine 2 di 3 Asus Padfone 2 Battery Replacement, Battery Removal: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord
    • Disconnect battery connecting cord using tweezers.
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team 5-4, Mcgee Fall 2014 Membro di USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Membri
7 Guide realizzate
Un commento
Pull the battery connector towards USB. You will break it if you pull it up, as I did.
I wouldn’t recommend metal tweezers as it could shortcut the battery.
Los Karlos - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 5,901
