Salta al contenuto principale
Asus Padfone 2 A68 Sub Cables Replacement
Cosa ti serve
  1. Asus Padfone 2 A68 Sub Cables Replacement, Power Down Device: passo 1, immagine 1 di 1
    • Hold down the power button.
  2. Asus Padfone 2 A68 Sub Cables Replacement, Remove Back Plate: passo 2, immagine 1 di 3 Asus Padfone 2 A68 Sub Cables Replacement, Remove Back Plate: passo 2, immagine 2 di 3 Asus Padfone 2 A68 Sub Cables Replacement, Remove Back Plate: passo 2, immagine 3 di 3
    • Use plastic opening tools to pry off the cover of the phone.
  3. Asus Padfone 2 A68 Sub Cables Replacement, Battery Removal: passo 3, immagine 1 di 3 Asus Padfone 2 A68 Sub Cables Replacement, Battery Removal: passo 3, immagine 2 di 3 Asus Padfone 2 A68 Sub Cables Replacement, Battery Removal: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
    • Disconnect battery connecting cord using tweezers.
  4. Asus Padfone 2 A68 Sub Cables Replacement, Remove Internal Back Plate: passo 4, immagine 1 di 2 Asus Padfone 2 A68 Sub Cables Replacement, Remove Internal Back Plate: passo 4, immagine 2 di 2
    • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
    • Use of magnetic pad will help with keeping track of screws.
    • Once screws are out, remove the plate.
  5. Asus Padfone 2 A68 Sub Cables Replacement, Removal of A68 Sub Cables: passo 5, immagine 1 di 1
    • Use tweezers to unplug the sub cables from the circuit board and housing.
  6. Asus Padfone 2 A68 Sub Cables Replacement, Replacing the A68 Sub Cables: passo 6, immagine 1 di 2 Asus Padfone 2 A68 Sub Cables Replacement, Replacing the A68 Sub Cables: passo 6, immagine 2 di 2
    • Plug in new sub cables to the circuit board and housing.
Conclusione
Erica
Membro da: 09/25/14
467 Reputazione
2 Guide realizzate
USF Tampa, Team 5-4, Mcgee Fall 2014 Membro di USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Membri
7 Guide realizzate
Un commento
Boas. Onde posso comprar este cabo?
rsebastiao - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,226
