Salta al contenuto principale
Asus PadFone S Rear Facing Camera Replacement
Cosa ti serve
  1. Asus PadFone S Rear Facing Camera Replacement, Remove Back Cover: passo 1, immagine 1 di 2 Asus PadFone S Rear Facing Camera Replacement, Remove Back Cover: passo 1, immagine 2 di 2
    • Place your thumb in the charging port and pry the back cover off of the phone.
    • Separate cover all the way around the sides of the phone.
  2. Asus PadFone S Rear Facing Camera Replacement, Remove Back Panel: passo 2, immagine 1 di 2 Asus PadFone S Rear Facing Camera Replacement, Remove Back Panel: passo 2, immagine 2 di 2
    • Remove all the screws on the back panel using a T5 Torx screwdriver.
    • Lift the back panel off to reveal the logic board and battery.
  3. Asus PadFone S Rear Facing Camera Replacement, Remove Back Camera: passo 3, immagine 1 di 3 Asus PadFone S Rear Facing Camera Replacement, Remove Back Camera: passo 3, immagine 2 di 3 Asus PadFone S Rear Facing Camera Replacement, Remove Back Camera: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • The back camera is located at the top left on the logic board.
    • Use tweezers to lift back camera strip from logic board.
    • Lift back camera out of logic board.
    • It is not necessary to remove logic board for removal of the back camera.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,366
