Salta al contenuto principale
Asus PadFone S Front Facing Camera Replacement
Cosa ti serve
  1. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: passo 1, immagine 1 di 1
    • Place your thumb in the charging port and pry the back cover off of the phone.
  2. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: passo 2, immagine 1 di 2 Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: passo 2, immagine 2 di 2
    • Remove all screws using the T5 Torx screwdriver
    • Lift the back panel off the phone.
  3. Asus PadFone S Front Facing Camera Replacement, Remove the Battery: passo 3, immagine 1 di 2 Asus PadFone S Front Facing Camera Replacement, Remove the Battery: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Disconnect the battery from the logic board using tweezers
    • Using the plastic opening tools, lift the battery up from its slot
    • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
  4. Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: passo 4, immagine 1 di 3 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: passo 4, immagine 2 di 3 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: passo 4, immagine 3 di 3
    • Once the Battery has been successfully removed, move on to the step 2.
  5. Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: passo 5, immagine 1 di 2 Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: passo 5, immagine 2 di 2
    • Disconnect the marked strips from the logic board using the tweezers.
    • Applying too much force may damage the strips/connectors.
    • Remember to remove speaker connection located at the bottom left hand corner.
  6. Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: passo 6, immagine 1 di 2 Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: passo 6, immagine 2 di 2
    • Disconnect the other two strips that connect the logic board to the phone.
  7. Asus PadFone S Front Facing Camera Replacement, Remove The Camera: passo 7, immagine 1 di 2 Asus PadFone S Front Facing Camera Replacement, Remove The Camera: passo 7, immagine 2 di 2
    • Turn over the logic board to locate the front camera.
    • Grasp the sides of the camera with the tweezers and carefully remove the camera from the logic board.
    • Applying to much force will damage the connective strip.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,616
