Salta al contenuto principale
Asus Memo Pad ME172V - Factory Reset , Password Removal
Panoramica Video
  1. Asus Memo Pad ME172V - Factory Reset , Password Removal, Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 1, immagine 1 di 3 Asus Memo Pad ME172V - Factory Reset , Password Removal, Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 1, immagine 2 di 3 Asus Memo Pad ME172V - Factory Reset , Password Removal, Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 1, immagine 3 di 3
    • First, try to pass the security with the Google account, registered on this tablet.
    • If you can't, then go to the next step.
  2. Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 2, immagine 1 di 3 Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 2, immagine 2 di 3 Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 2, immagine 3 di 3
    • Switch off the tablet and eject the memory card.
    • If you haven't memory card, you can use another, but it must be formatted at FAT32.
    • Google "asus memo pad how to reset to factory settings" and find the link to the official ASUS website.
    • Dounload "cleandata.zip".
    • Direct link to "cleandata.zip"
  3. Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 3, immagine 1 di 3 Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 3, immagine 2 di 3 Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 3, immagine 3 di 3
    • Open "cleandata.zip" archive and copy contents to the ROOT directory on the microSD.
  4. Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 4, immagine 1 di 3 Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 4, immagine 2 di 3 Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 4, immagine 3 di 3
    • Put the memory card in the tablet and switch on it.
    • The tablet will go directly to the Android BSP Installation menu
  5. Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 5, immagine 1 di 3 Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 5, immagine 2 di 3 Asus Memo Pad ME172V - Factory Reset , Password Removal: passo 5, immagine 3 di 3
    • In this menu use Volume Up/Down for movement and Power On to confirm.
    • Choose "clear user data"
    • After a while the tablet will ask you to remove the media (memory card).
    • The tablet tablet will restart and restore the system automatically.
    • Before installing the micro SD back, erase last copied files.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
Conclusione
Altre 24 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.341 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.540 Guide realizzate
19 Commenti
the tablet don,t go to andriod bsp instalation menu
charming boy - Replica
Try with another micro SD card.
ZFix -
Hey All, I was able to complete this task by placing the individual files from "cleandata.zip" onto the memory card. I tried placing the files from the zip folder onto the memory card, but that didn't work. Place only the individual files from the zip folder onto the memory card and re-boot and it will work...
Monk
Monk Paloo - Replica
make sure format it to FAT32
donie cahyadi - Replica
Power up the Tablet while PRESSING the (POWER)+(VOLUME UP)+(VOLUME DOWN) buttons all at the same time for several seconds..... the Android native boot loader will load allowing you to delete data and restore to factory defaults.....
Eric Fulton - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 34
Tutti i Tempi: 72,402
