Salta al contenuto principale
Asus MeMo Pad 10 ME102A Back Panel Replacement
Cosa ti serve
  1. Asus MeMo Pad 10 ME102A Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Insert the blue plastic opening tool into the seam between the back panel and the chassis.
    • When removing the back panel, remember to keep the device face down on a flat surface in order to prevent dropping the device or anything inside of the device.
  2. Asus MeMo Pad 10 ME102A Back Panel Replacement: passo 2, immagine 1 di 1
    • Slide the plastic opener around the tablet. There will be spots of resistance. These should gently pop open as the tool slides through the seam.
  3. Asus MeMo Pad 10 ME102A Back Panel Replacement: passo 3, immagine 1 di 1
    • After all of the clips have been opened, the back panel should be free to remove by hand
Conclusione
USF Tampa, Team 11-3, Blackwell Fall 2016 Membro di USF Tampa, Team 11-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,764
