Salta al contenuto principale
Asus MeMO Pad HD 8 ME180A Motherboard Replacement
Cosa ti serve
  1. Asus MeMO Pad HD 8 ME180A Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Asus MeMO Pad HD 8 ME180A Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Use a plastic opening tool to separate the back half from the front half.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Be careful not to lose them.
  2. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
  3. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 3, immagine 1 di 3 Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 3, immagine 2 di 3 Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 3, immagine 3 di 3
    • Lift the white bar on the ZIF connector and pull the metal connector out.
  4. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 4, immagine 1 di 2 Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 4, immagine 2 di 2
    • Using your spudger, press down on the two spots shown in order to release the cables.
    • Ensure that the touchscreen cables are fully disconnected.
  5. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 5, immagine 1 di 2 Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 5, immagine 2 di 2
    • Using a PH#0 screwdriver, remove the twelve silver 3.2 mm screws.
    • Pull the battery out.
  6. Asus MeMO Pad HD 8 ME180A Motherboard Replacement, Motherboard: passo 6, immagine 1 di 1
    • Disconnect GPS Antenna cable.
  7. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 7, immagine 1 di 1
    • Flip the latch and pull the ribbon cable to disconnect the ZIF connector.
  8. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 8, immagine 1 di 1
  9. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 9, immagine 1 di 2 Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 9, immagine 2 di 2
    • Use a PH#0 screwdriver to unscrew the six 3.0 mm black screws.
    • Lift the motherboard straight up to remove.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 2-5, Nance Fall 2016 Membro di USF Tampa, Team 2-5, Nance Fall 2016
USFT-NANCE-F16S2G5
3 Membri
10 Guide realizzate
2 Commenti
Où je peux avoir une carte mère pour asus memo pad8 me 180
David Leblanc - Replica
Shouldn’t there be a step to handle the camera?
Haggai Eran - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 770
