Salta al contenuto principale
Asus MeMO Pad 7 ME170C Battery Replacement
Cosa ti serve
  1. Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: passo 1, immagine 1 di 3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: passo 1, immagine 2 di 3 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Before beginning to disassemble, Power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Gently wedge a Jimmy into the seam of the device.
    • Gently pry the Jimmy all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C  Battery Replacement: passo 2, immagine 1 di 3 Asus MeMO Pad 7 ME170C  Battery Replacement: passo 2, immagine 2 di 3 Asus MeMO Pad 7 ME170C  Battery Replacement: passo 2, immagine 3 di 3
    • Locate the black bundle cable connector attached to the battery of the phone.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Using a plastic opening tool, gently slide the black bundle cable connector towards the battery in a back and forth motion until loosened and it slides out of connection port.
  3. Asus MeMO Pad 7 ME170C  Battery Replacement: passo 3, immagine 1 di 3 Asus MeMO Pad 7 ME170C  Battery Replacement: passo 3, immagine 2 di 3 Asus MeMO Pad 7 ME170C  Battery Replacement: passo 3, immagine 3 di 3
    • Using a plastic opening tool, pry out the batteries to loosen them out.
    • The battery will be pried out of its port.
    • Lift the battery out of its port
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,151
