Salta al contenuto principale
Asus M51E-B2 Swivel Camera Replacement
Cosa ti serve
  1. Asus M51E-B2  Swivel Camera Replacement, Swivel Camera: passo 1, immagine 1 di 1
    • Open the laptop.
    • Press and hold the power button until the laptop powers off.
  2. Asus M51E-B2  Swivel Camera Replacement: passo 2, immagine 1 di 2 Asus M51E-B2  Swivel Camera Replacement: passo 2, immagine 2 di 2
    • Use a metal spudger prying tool to remove the outer screen cover of the laptop.
    • Gently work your way clockwise around the outer part of the screen.
  3. Asus M51E-B2  Swivel Camera Replacement: passo 3, immagine 1 di 2 Asus M51E-B2  Swivel Camera Replacement: passo 3, immagine 2 di 2
    • Use the Phillips PH0 head screwdriver to remove the two 2.5 mm screws located on the left side of the camera.
    • Use the Phillips PH0 head screwdriver to remove the one 2.5 millimeter screw that goes through the left side of the camera.
  4. Asus M51E-B2  Swivel Camera Replacement: passo 4, immagine 1 di 1
    • Find the wiring harness on the right side of the camera.
    • Using your fingers, gently remove the wiring harness connected to the right side of the camera.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 286
