Salta al contenuto principale
Asus K55N-DS81 Rear Panel Replacement
Cosa ti serve
  1. Asus K55N-DS81 Rear Panel Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Ensure that the laptop is powered off prior to following this guide.
  2. Asus K55N-DS81 Rear Panel Replacement: passo 2, immagine 1 di 2 Asus K55N-DS81 Rear Panel Replacement: passo 2, immagine 2 di 2
    • Pull the latch to the right of the battery to the right.
  3. Asus K55N-DS81 Rear Panel Replacement: passo 3, immagine 1 di 2 Asus K55N-DS81 Rear Panel Replacement: passo 3, immagine 2 di 2
    • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
  4. Asus K55N-DS81 Rear Panel Replacement: passo 4, immagine 1 di 2 Asus K55N-DS81 Rear Panel Replacement: passo 4, immagine 2 di 2
    • While holding the second latch from the previous step, use another hand to reach underneath the battery.
    • Pull the battery upwards and away from the laptop to remove it.
  5. Asus K55N-DS81 Rear Panel Replacement, Rear Panel: passo 5, immagine 1 di 2 Asus K55N-DS81 Rear Panel Replacement, Rear Panel: passo 5, immagine 2 di 2
    • Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
  6. Asus K55N-DS81 Rear Panel Replacement: passo 6, immagine 1 di 3 Asus K55N-DS81 Rear Panel Replacement: passo 6, immagine 2 di 3 Asus K55N-DS81 Rear Panel Replacement: passo 6, immagine 3 di 3
    • Remove the panel by pushing away from the laptop until the panel is free of the laptop.
    • Lift to remove the panel.
Conclusione
IUPUI, Team S2-G1, Baechle Fall 2018 Membro di IUPUI, Team S2-G1, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 360
