Introduzione
The fan in your laptop is essential in keeping your laptop from overheating. If your device overheats this can cause damage to all internal hardware. If your fan fails, you must first remove the motherboard from your laptop.
Cosa ti serve
Turn off the computer and disconnect the charging cable from the laptop.
Push the two locking mechanisms at the top of the laptop outward and pull the battery away from the laptop.
Remove the following seventeen screws from the back panel of your laptop using your Phillips #0 screwdriver:
Sixteen black 7.0 mm Phillips #0 screws.
One black 4.0 mm Phillips #0 screw.
The two screws nearest to the rubber pads are larger in diameter than the others.
Also, you need to disconnect the antenna wires from the wireless card.
Using the blue prying tool, separate the keyboard from the palm rest by inserting the prying tool into each of the five tabs at the top of the keyboard.
Slowly remove the keyboard by gently pulling the keyboard away from the palm rest.
On a BBR1, which looks identical to the BBR7, the blue Ifixit prying tool is slightly too wide, at both ends, to fit in the tab slot. The Ifixit black spudger does fit. Don’t try to pry the keyboard up. Put the spudger in the slot and press down and back towards the screen. The keyboard should lift out easily. It doesn’t snap out.
Using your fingers, slowly remove the silver ribbon cable from the laptop by disconnecting it from its connector.
Remove the six silver 6.0 mm Phillips #0 screws using your Phillips #0 screwdriver.
My K53E had 7 screws in this step - one on either side of the smaller ribbon shown in step 8. And they were black, not silver.
Use your fingers to gently disconnect the following cables from your laptop:
Power button cable.
Touchpad cable.
Lift the black bar on each connector with a pointed tool such as the pointed end on the Ifixit spludger before pulling the cable out.
Altre 3 persone hanno completato questa guida.
