Introduzione
Fans can overheat and stop working. This guide will help you be able to remove and replace the fan inside the ASUS K50IJ.
Cosa ti serve
Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
