Salta al contenuto principale
Asus K50IJ Fan Replacement
Cosa ti serve
  1. Asus K50IJ Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
  2. Asus K50IJ Fan Replacement: passo 2, immagine 1 di 3 Asus K50IJ Fan Replacement: passo 2, immagine 2 di 3 Asus K50IJ Fan Replacement: passo 2, immagine 3 di 3
    • Lift the exposed lip and remove the battery cover.
  3. Asus K50IJ Fan Replacement: passo 3, immagine 1 di 3 Asus K50IJ Fan Replacement: passo 3, immagine 2 di 3 Asus K50IJ Fan Replacement: passo 3, immagine 3 di 3
    • Press the tabs on the battery and lift them. The battery should come out easily.
  4. Asus K50IJ Fan Replacement, Fan: passo 4, immagine 1 di 3 Asus K50IJ Fan Replacement, Fan: passo 4, immagine 2 di 3 Asus K50IJ Fan Replacement, Fan: passo 4, immagine 3 di 3
    • Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
  5. Asus K50IJ Fan Replacement: passo 5, immagine 1 di 1
    • Remove the one .5 mm screw located in the top right corner of the battery compartment.
  6. Asus K50IJ Fan Replacement: passo 6, immagine 1 di 2 Asus K50IJ Fan Replacement: passo 6, immagine 2 di 2
    • Remove the bottom panel by sliding it toward the hinges and lifting the back panel up.
  7. Asus K50IJ Fan Replacement: passo 7, immagine 1 di 1
    • Unplug the wire cable attached to the fan by pulling it out .
  8. Asus K50IJ Fan Replacement: passo 8, immagine 1 di 2 Asus K50IJ Fan Replacement: passo 8, immagine 2 di 2
    • Using the PH1 screwdriver, remove the 3 .75mm screws labeled as 1, 2, and 3 on the fan. NOTE these screws have the labels "1", "2", and "3" next to them.
    • Lift the fan up with your fingers.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 881
