Salta al contenuto principale
Asus GL551JW-AH71 Wi-Fi Card Replacement
Cosa ti serve
  1. Asus GL551JW-AH71 Wi-Fi Card Replacement, Battery: passo 1, immagine 1 di 1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Wi-Fi Card Replacement: passo 2, immagine 1 di 2 Asus GL551JW-AH71 Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Wi-Fi Card Replacement: passo 3, immagine 1 di 2 Asus GL551JW-AH71 Wi-Fi Card Replacement: passo 3, immagine 2 di 2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Wi-Fi Card Replacement, Wi-Fi Card: passo 4, immagine 1 di 2 Asus GL551JW-AH71 Wi-Fi Card Replacement, Wi-Fi Card: passo 4, immagine 2 di 2
    • Using a Phillips #000 screwdriver, remove the two 16mm screws securing the access panel to the laptop.
  5. Asus GL551JW-AH71 Wi-Fi Card Replacement: passo 5, immagine 1 di 1
    • Gently remove the cover once the screws are removed.
  6. Asus GL551JW-AH71 Wi-Fi Card Replacement: passo 6, immagine 1 di 1
    • Locate the Wi-Fi card and detach both coaxial cables that are connected to the card.
    • The pictures in this step do not show a Wi-Fi card. The location where the Wi-Fi card would be located is indicated by the red rectangle.
  7. Asus GL551JW-AH71 Wi-Fi Card Replacement: passo 7, immagine 1 di 1
    • Grasp the Wi-Fi card gently and remove it carefully.
    • The pictures in this step do not show a Wi-Fi card, since it is missing from this particular device.
Conclusione
Altre 2 persone hanno completato questa guida.
William Kelley
Membro da: 03/20/19
1.035 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 902
