Introduzione
This guide outlines how to remove the upper assembly from the Asus GL551JW-AH71. This guide primarily serves as a prerequisite for guides that require the removal of the upper assembly to access the motherboard, fan and display cables.
Cosa ti serve
Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
