Salta al contenuto principale
Asus GL551JW-AH71 Fan Replacement
Cosa ti serve
  1. Asus GL551JW-AH71 Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Fan Replacement: passo 2, immagine 1 di 2 Asus GL551JW-AH71 Fan Replacement: passo 2, immagine 2 di 2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Fan Replacement: passo 3, immagine 1 di 2 Asus GL551JW-AH71 Fan Replacement: passo 3, immagine 2 di 2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Fan Replacement, Optical Drive: passo 4, immagine 1 di 2 Asus GL551JW-AH71 Fan Replacement, Optical Drive: passo 4, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
  5. Asus GL551JW-AH71 Fan Replacement: passo 5, immagine 1 di 3 Asus GL551JW-AH71 Fan Replacement: passo 5, immagine 2 di 3 Asus GL551JW-AH71 Fan Replacement: passo 5, immagine 3 di 3
    • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
  6. Asus GL551JW-AH71 Fan Replacement: passo 6, immagine 1 di 2 Asus GL551JW-AH71 Fan Replacement: passo 6, immagine 2 di 2
    • Gently grasp the optical drive assembly and slide it out of the laptop body.
  7. Asus GL551JW-AH71 Fan Replacement, Upper Assembly: passo 7, immagine 1 di 2 Asus GL551JW-AH71 Fan Replacement, Upper Assembly: passo 7, immagine 2 di 2
    • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
  8. Asus GL551JW-AH71 Fan Replacement: passo 8, immagine 1 di 2 Asus GL551JW-AH71 Fan Replacement: passo 8, immagine 2 di 2
    • Carefully remove the access panel.
  9. Asus GL551JW-AH71 Fan Replacement: passo 9, immagine 1 di 2 Asus GL551JW-AH71 Fan Replacement: passo 9, immagine 2 di 2
    • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
  10. Asus GL551JW-AH71 Fan Replacement: passo 10, immagine 1 di 1
    • Turn the laptop over and open the screen.
  11. Asus GL551JW-AH71 Fan Replacement: passo 11, immagine 1 di 3 Asus GL551JW-AH71 Fan Replacement: passo 11, immagine 2 di 3 Asus GL551JW-AH71 Fan Replacement: passo 11, immagine 3 di 3
    • Gently pry open the case with an iFixit opening tool.
    • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
  12. Asus GL551JW-AH71 Fan Replacement: passo 12, immagine 1 di 3 Asus GL551JW-AH71 Fan Replacement: passo 12, immagine 2 di 3 Asus GL551JW-AH71 Fan Replacement: passo 12, immagine 3 di 3
    • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
    • Unplug the display connector from the motherboard.
    • Remove the upper assembly.
  13. Asus GL551JW-AH71 Fan Replacement, Fan: passo 13, immagine 1 di 1
    • Place the separated motherboard keyboard side down.
  14. Asus GL551JW-AH71 Fan Replacement: passo 14, immagine 1 di 3 Asus GL551JW-AH71 Fan Replacement: passo 14, immagine 2 di 3 Asus GL551JW-AH71 Fan Replacement: passo 14, immagine 3 di 3
    • Unplug the fan connector cable from the motherboard with an iFixit opening tool.
  15. Asus GL551JW-AH71 Fan Replacement: passo 15, immagine 1 di 2 Asus GL551JW-AH71 Fan Replacement: passo 15, immagine 2 di 2
    • With a Phillips #00 screwdriver, remove the three 5mm screws that hold the fan in place.
  16. Asus GL551JW-AH71 Fan Replacement: passo 16, immagine 1 di 2 Asus GL551JW-AH71 Fan Replacement: passo 16, immagine 2 di 2
    • Gently remove the fan from the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
William Kelley
Membro da: 03/20/19
1.035 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 36
Tutti i Tempi: 1,530
