Salta al contenuto principale
Asus GL551JW-AH71 Display Assembly Replacement
Cosa ti serve
  1. Asus GL551JW-AH71 Display Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Display Assembly Replacement: passo 2, immagine 1 di 2 Asus GL551JW-AH71 Display Assembly Replacement: passo 2, immagine 2 di 2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Display Assembly Replacement: passo 3, immagine 1 di 2 Asus GL551JW-AH71 Display Assembly Replacement: passo 3, immagine 2 di 2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Display Assembly Replacement, Optical Drive: passo 4, immagine 1 di 2 Asus GL551JW-AH71 Display Assembly Replacement, Optical Drive: passo 4, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
  5. Asus GL551JW-AH71 Display Assembly Replacement: passo 5, immagine 1 di 3 Asus GL551JW-AH71 Display Assembly Replacement: passo 5, immagine 2 di 3 Asus GL551JW-AH71 Display Assembly Replacement: passo 5, immagine 3 di 3
    • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
  6. Asus GL551JW-AH71 Display Assembly Replacement: passo 6, immagine 1 di 2 Asus GL551JW-AH71 Display Assembly Replacement: passo 6, immagine 2 di 2
    • Gently grasp the optical drive assembly and slide it out of the laptop body.
  7. Asus GL551JW-AH71 Display Assembly Replacement, Upper Assembly: passo 7, immagine 1 di 2 Asus GL551JW-AH71 Display Assembly Replacement, Upper Assembly: passo 7, immagine 2 di 2
    • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
  8. Asus GL551JW-AH71 Display Assembly Replacement: passo 8, immagine 1 di 2 Asus GL551JW-AH71 Display Assembly Replacement: passo 8, immagine 2 di 2
    • Carefully remove the access panel.
  9. Asus GL551JW-AH71 Display Assembly Replacement: passo 9, immagine 1 di 2 Asus GL551JW-AH71 Display Assembly Replacement: passo 9, immagine 2 di 2
    • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
  10. Asus GL551JW-AH71 Display Assembly Replacement: passo 10, immagine 1 di 1
    • Turn the laptop over and open the screen.
  11. Asus GL551JW-AH71 Display Assembly Replacement: passo 11, immagine 1 di 3 Asus GL551JW-AH71 Display Assembly Replacement: passo 11, immagine 2 di 3 Asus GL551JW-AH71 Display Assembly Replacement: passo 11, immagine 3 di 3
    • Gently pry open the case with an iFixit opening tool.
    • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
  12. Asus GL551JW-AH71 Display Assembly Replacement: passo 12, immagine 1 di 3 Asus GL551JW-AH71 Display Assembly Replacement: passo 12, immagine 2 di 3 Asus GL551JW-AH71 Display Assembly Replacement: passo 12, immagine 3 di 3
    • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
    • Unplug the display connector from the motherboard.
    • Remove the upper assembly.
  13. Asus GL551JW-AH71 Display Assembly Replacement, Display Assembly: passo 13, immagine 1 di 2 Asus GL551JW-AH71 Display Assembly Replacement, Display Assembly: passo 13, immagine 2 di 2
    • Remove the three 5mm screws located in each circle with a Phillips #000 screwdriver.
    • A total of twelve 5mm screw should be removed in order to free the display assembly from the base.
  14. Asus GL551JW-AH71 Display Assembly Replacement: passo 14, immagine 1 di 2 Asus GL551JW-AH71 Display Assembly Replacement: passo 14, immagine 2 di 2
    • Lift the display assembly up, separating it from the base of the device.
  15. Asus GL551JW-AH71 Display Assembly Replacement: passo 15, immagine 1 di 3 Asus GL551JW-AH71 Display Assembly Replacement: passo 15, immagine 2 di 3 Asus GL551JW-AH71 Display Assembly Replacement: passo 15, immagine 3 di 3
    • Using a plastic opening tool, separate the bezel from the screen.
    • Insert the tool and slide it right to left to release the bezel from the screen.
  16. Asus GL551JW-AH71 Display Assembly Replacement: passo 16, immagine 1 di 2 Asus GL551JW-AH71 Display Assembly Replacement: passo 16, immagine 2 di 2
    • Remove the four screws using a Phillips #0 screwdriver.
  17. Asus GL551JW-AH71 Display Assembly Replacement: passo 17, immagine 1 di 2 Asus GL551JW-AH71 Display Assembly Replacement: passo 17, immagine 2 di 2
    • Grab the screen in the corners and lift up to remove it.
Conclusione
Altre 3 persone hanno completato questa guida.
Alec Pimentel
Membro da: 03/21/19
258 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 812
