Introduzione
This guide outlines how to replace the display assembly for the Asus GL551JW-AH71.
Cosa ti serve
Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
Remove the three 5mm screws located in each circle with a Phillips #000 screwdriver.
A total of twelve 5mm screw should be removed in order to free the display assembly from the base.
Altre 3 persone hanno completato questa guida.
