Salta al contenuto principale
Asus G74SX-BBK7 Trackpad Button Replacement
Cosa ti serve
  1. Asus G74SX-BBK7 Trackpad Button Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the 13mm screw on the bottom of the laptop.
    • Take off the back panel.
  2. Asus G74SX-BBK7 Trackpad Button Replacement: passo 2, immagine 1 di 1
    • Now, unscrew and remove the 6mm Phillips #0 screw next to the optical drive.
  3. Asus G74SX-BBK7 Trackpad Button Replacement: passo 3, immagine 1 di 2 Asus G74SX-BBK7 Trackpad Button Replacement: passo 3, immagine 2 di 2
    • Lastly, use a plastic opening tool to remove the optical drive from its slot.
  4. Asus G74SX-BBK7 Trackpad Button Replacement, Trackpad Button: passo 4, immagine 1 di 1
    • Remove the two 6mm Phillips #0 screws that were previously covered by the optical drive using a Phillips #0 screwdriver.
  5. Asus G74SX-BBK7 Trackpad Button Replacement: passo 5, immagine 1 di 1
    • First, remove the five 10mm Phillips #0 screws from the back of the computer near the top.
    • Remove all eighteen 6mm Phillips #0 screws from the bottom of the computer.
    • Some of the screws are set very deeply in the back case - you will need a long and narrow screwdriver to remove them.
  6. Asus G74SX-BBK7 Trackpad Button Replacement: passo 6, immagine 1 di 2 Asus G74SX-BBK7 Trackpad Button Replacement: passo 6, immagine 2 di 2
    • Next, pry open back plastic cover using a metal spudger.
    • Unscrew the four 10mm Phillips #0 screws under the cover.
  7. Asus G74SX-BBK7 Trackpad Button Replacement: passo 7, immagine 1 di 3 Asus G74SX-BBK7 Trackpad Button Replacement: passo 7, immagine 2 di 3 Asus G74SX-BBK7 Trackpad Button Replacement: passo 7, immagine 3 di 3
    • Lay laptop opened and completely flat.
    • Using the metal spudger, slowly pry open the front main panel by going around each side.
    • Lift the top panel out, pulling the cable strips out of their sockets. These will be reattached later.
    • Be careful when lifting the top panel. There are cable strips attached to the motherboard that need to be removed.
  8. Asus G74SX-BBK7 Trackpad Button Replacement: passo 8, immagine 1 di 2 Asus G74SX-BBK7 Trackpad Button Replacement: passo 8, immagine 2 di 2
    • After separating the main panel and the motherboard, unscrew two 6mm Phillips #0 screws.
    • Remove the mouse button.
  9. Asus G74SX-BBK7 Trackpad Button Replacement: passo 9, immagine 1 di 3 Asus G74SX-BBK7 Trackpad Button Replacement: passo 9, immagine 2 di 3 Asus G74SX-BBK7 Trackpad Button Replacement: passo 9, immagine 3 di 3
    • To reconnect the motherboard and main panel, insert strips back to their corresponding location.
    • To do this, first remove the tape and open up the tab. Plug in the strip and and close the tab.
    • It may be helpful to have someone help you hold the main panel while you reconnect the strips.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 5-10, Maness Spring 2015 Membro di Cal Poly, Team 5-10, Maness Spring 2015
CPSU-MANESS-S15S5G10
4 Membri
6 Guide realizzate
Un commento
Where did you find the part?
websmiths - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 4,809
