Salta al contenuto principale
Asus G74SX-BBK7 RAM Replacement
Cosa ti serve
  1. Asus G74SX-BBK7 RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the large 13mm screw on the bottom of the laptop.
    • Take off the back panel.
  2. Asus G74SX-BBK7 RAM Replacement: passo 2, immagine 1 di 3 Asus G74SX-BBK7 RAM Replacement: passo 2, immagine 2 di 3 Asus G74SX-BBK7 RAM Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Locate the RAM near the center of the computer.
    • Push gently on the metal pins that are on both sides of the RAM sticks.
    • Before touching the RAM, discharge any built-up static by touching a metal surface or wearing an antistatic wrist strap.
  3. Asus G74SX-BBK7 RAM Replacement: passo 3, immagine 1 di 1
    • When you push on the pins, the RAM will pop up. Gently remove it from its socket.
    • Repeat the third and fourth step for the second stick of RAM, located behind the first stick.
Conclusione
Altre 2 persone hanno completato questa guida.
Josiah Avery
Membro da: 04/15/15
131 Reputazione
1 Guida realizzata
Cal Poly, Team 5-10, Maness Spring 2015 Membro di Cal Poly, Team 5-10, Maness Spring 2015
CPSU-MANESS-S15S5G10
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 733
