Salta al contenuto principale
Asus G74SX-BBK7 Hard Drive Replacement
Cosa ti serve
  1. Asus G74SX-BBK7 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the large screw on the bottom of the laptop.
    • After the screw is removed, take off the back panel.
  2. Asus G74SX-BBK7 Hard Drive Replacement: passo 2, immagine 1 di 2 Asus G74SX-BBK7 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Locate the hard drive in the lower left corner.
    • Unscrew four 6mm Phillip #0 screws from the hard drive mounting.
  3. Asus G74SX-BBK7 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Unplug and remove the hard drive by pulling up on the black tab on top of the hard drive.
    • A spudger may assist in prying up the black tab.
  4. Asus G74SX-BBK7 Hard Drive Replacement: passo 4, immagine 1 di 2 Asus G74SX-BBK7 Hard Drive Replacement: passo 4, immagine 2 di 2
    • Unscrew two 3mm Phillips #0 screws to remove the casing on the hard drive.
Conclusione
Cal Poly, Team 5-10, Maness Spring 2015 Membro di Cal Poly, Team 5-10, Maness Spring 2015
CPSU-MANESS-S15S5G10
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 3,171
