Introduzione
Use this guide to remove and replace the RAM on the Asus G73JH-RBBX05.
Cosa ti serve
Locate the two, 4mm screws on the back of the laptop and remove them using a PH0 screwdriver.
Altre 4 persone hanno completato questa guida.
Un commento
Unfortunately, not very helpful when the only one that needs replacing is the only one not noted in this guide. Under the inside of the board, right behind the third RAM stick, there is a fourth that requires almost a total disassembly of the unit to access.
