Salta al contenuto principale
Asus G73JH-RBBX05 Hard Drive Replacement
Cosa ti serve
  1. Asus G73JH-RBBX05 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip the laptop over and remove the two 4mm screws located at the bottom of the laptop with the PH0 screwdriver.
  2. Asus G73JH-RBBX05 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool or finger, remove the access panel.
    • Apply constant force until the panel releases from the clips underneath.
  3. Asus G73JH-RBBX05 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Locate the two, 4mm screws on the hard drive. Remove them with the PH0 screwdriver.
  4. Asus G73JH-RBBX05 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Using the black tab located on the hard drive, pull out the hard drive.
Conclusione
Cal Poly, Team 22-11, Maness Winter 2017 Membro di Cal Poly, Team 22-11, Maness Winter 2017
CPSU-MANESS-W17S22G11
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 757
