Salta al contenuto principale
Asus G53JW-A1 Battery Replacement
  1. Asus G53JW-A1 Battery Replacement, Battery: passo 1, immagine 1 di 2 Asus G53JW-A1 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Start with the laptop upside-down.
    • Turn the laptop so that the battery is facing you.
  2. Asus G53JW-A1 Battery Replacement: passo 2, immagine 1 di 3 Asus G53JW-A1 Battery Replacement: passo 2, immagine 2 di 3 Asus G53JW-A1 Battery Replacement: passo 2, immagine 3 di 3
    • Look to the right of the battery for a small black switch.
    • Slide the right side switch to the right, away from the battery.
    • When the switch is in the correct position, a red sticker will be visible underneath the switch.
    • On the left side of the battery is another black switch. Slide this to the left, away from the battery, and hold it in place there.
    • The left side switch does not have a red sticker underneath.
    • Slide the battery towards yourself.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 240
