Salta al contenuto principale
Asus G501JW-BHI7N12 Speakers Replacement
Cosa ti serve
  1. Asus G501JW-BHI7N12 Speakers Replacement, Battery: passo 1, immagine 1 di 2 Asus G501JW-BHI7N12 Speakers Replacement, Battery: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Attach the clip of your anti-static wrist strap to the case of the laptop. This prevents any accidents that could fry the motherboard.
    • Remove the four 7.0mm Philips #0 screws around the battery.
  2. Asus G501JW-BHI7N12 Speakers Replacement: passo 2, immagine 1 di 1
    • Unplug the connector highlighted in this picture by pulling it up and out of it's seating, then pull the battery away from the motherboard and remove the battery.
  3. Asus G501JW-BHI7N12 Speakers Replacement, Speakers: passo 3, immagine 1 di 1
    • Disconnect the white cables.
    • The first white cable is located above the left speaker. The second and the third white cables are located along the left side of the trackpad.
  4. Asus G501JW-BHI7N12 Speakers Replacement: passo 4, immagine 1 di 1
    • Using the metal spudger, insert the metal spudger between the speaker and pry up to remove it.
  5. Asus G501JW-BHI7N12 Speakers Replacement: passo 5, immagine 1 di 1
    • Remove the speakers from both sides following the previous step.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 277
