Salta al contenuto principale
Asus G501JW-BHI7N12 Cooling Fan Replacement
Cosa ti serve
  1. Asus G501JW-BHI7N12 Cooling Fan Replacement, Cooling Fan: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
  2. Asus G501JW-BHI7N12 Cooling Fan Replacement: passo 2, immagine 1 di 1
    • Unscrew and remove the four 5mm Phillips #0 screws from the cooling fan.
  3. Asus G501JW-BHI7N12 Cooling Fan Replacement: passo 3, immagine 1 di 1
    • Remove 4 pin connector from mother board.
  4. Asus G501JW-BHI7N12 Cooling Fan Replacement: passo 4, immagine 1 di 1
    • Slide cooling fan out from underneath the copper heat sink.
    • The cooling fan will be clipped to the case, we suggest pulling it toward the front of the case. Using the spudger can be helpful to work the fan loose.
  5. Asus G501JW-BHI7N12 Cooling Fan Replacement: passo 5, immagine 1 di 1
    • One of the fans will have a connector that partially covers it. Pull the connector loose by flipping up the plastic clamps on both ends and follow steps 2-4.
Conclusione
Dustin Annis
Membro da: 02/08/17
211 Reputazione
2 Guide realizzate
UW Tacoma, Team 2-1, Rose Winter 2017 Membro di UW Tacoma, Team 2-1, Rose Winter 2017
UWT-ROSE-W17S2G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,011
