Salta al contenuto principale
Asus F555LA-AB31 Hard Drive Replacement
Cosa ti serve
  1. Asus F555LA-AB31 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Remove ten 18mm Phillips #0 screws from the backside of the device.
    • Removal of the RAM access panel is not necessary.
  2. Asus F555LA-AB31 Hard Drive Replacement: passo 2, immagine 1 di 3 Asus F555LA-AB31 Hard Drive Replacement: passo 2, immagine 2 di 3 Asus F555LA-AB31 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Carefully fold the device open.
    • Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
    • To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
  3. Asus F555LA-AB31 Hard Drive Replacement: passo 3, immagine 1 di 3 Asus F555LA-AB31 Hard Drive Replacement: passo 3, immagine 2 di 3 Asus F555LA-AB31 Hard Drive Replacement: passo 3, immagine 3 di 3
    • Fold the keyboard section of the laptop up towards the screen to fully expose the inside of the device.
    • Unscrew the four 4mm Phillips #0 screws holding down the hard drive.
  4. Asus F555LA-AB31 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Disconnect the ZIF connector and lift the hard drive out of the space.
Conclusione
Un commento
Boo, 10 screws in first step are not all the same length, 4 screws in third step are not correctly indicated in the image (nor are they all in view in said image). Finally, there’s a hard drive bracket that is not included in the guide which is important to note how it is positioned to reinstall correctly.
Jeb - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,628
