Salta al contenuto principale
Asus F554LA-WS52 Touchpad Replacement
Cosa ti serve
  1. Asus F554LA-WS52 Touchpad Replacement, Touchpad: passo 1, immagine 1 di 3 Asus F554LA-WS52 Touchpad Replacement, Touchpad: passo 1, immagine 2 di 3 Asus F554LA-WS52 Touchpad Replacement, Touchpad: passo 1, immagine 3 di 3
    • Make sure your notebook device is unplugged and turned off before opening it up.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Touchpad Replacement: passo 2, immagine 1 di 3 Asus F554LA-WS52 Touchpad Replacement: passo 2, immagine 2 di 3 Asus F554LA-WS52 Touchpad Replacement: passo 2, immagine 3 di 3
    • Once the screws are removed, carefully lift both sides of the plastic keyboard/touch pad cover with a plastic opening tool.
  3. Asus F554LA-WS52 Touchpad Replacement: passo 3, immagine 1 di 1
    • Lift the plastic cover and unplug the three data cords (not all pictured) under the cover from the keyboard and motherboard.
  4. Asus F554LA-WS52 Touchpad Replacement: passo 4, immagine 1 di 3 Asus F554LA-WS52 Touchpad Replacement: passo 4, immagine 2 di 3 Asus F554LA-WS52 Touchpad Replacement: passo 4, immagine 3 di 3
    • Once you've removed the plastic cover, flip it over.
    • Next, carefully remove the tape from the bottom side of your touch pad.
  5. Asus F554LA-WS52 Touchpad Replacement: passo 5, immagine 1 di 1
    • Locate and unscrew the three 3.2 mm at the top edge of the touch pad using the Phillips #0 screwdriver.
  6. Asus F554LA-WS52 Touchpad Replacement: passo 6, immagine 1 di 3 Asus F554LA-WS52 Touchpad Replacement: passo 6, immagine 2 di 3 Asus F554LA-WS52 Touchpad Replacement: passo 6, immagine 3 di 3
    • Gently push the front of the touch pad with your finger to remove it from its position within the keyboard.
    • Replace touch pad.
Conclusione
Clint Eagle
Membro da: 10/09/18
300 Reputazione
1 Guida realizzata
USF Tampa, Team S1-G2, Leahy Fall 2018 Membro di USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 239
