Salta al contenuto principale
Asus F554LA-WS52 Keyboard Replacement
Cosa ti serve
  1. Asus F554LA-WS52 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Asus F554LA-WS52 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Keyboard Replacement: passo 2, immagine 1 di 3 Asus F554LA-WS52 Keyboard Replacement: passo 2, immagine 2 di 3 Asus F554LA-WS52 Keyboard Replacement: passo 2, immagine 3 di 3
    • Flip the notebook back over.
    • Gently lift and remove the keyboard with a plastic opening tool.
  3. Asus F554LA-WS52 Keyboard Replacement: passo 3, immagine 1 di 1
    • (Not pictured) Remove the three cables attached to the keyboard and one from the touch-pad.
    • (Not pictured) With the plastic opening tool, pry off the metal separation plate from the keyboard.
    • (Not pictured) With the plastic opening tool, gently pry the keyboard from its position and replace.
Conclusione
Aaron Ratliff
Membro da: 10/09/18
527 Reputazione
4 Guide realizzate
USF Tampa, Team S1-G2, Leahy Fall 2018 Membro di USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 329
