Salta al contenuto principale
Asus F554LA-WS52 Disc Drive
Cosa ti serve
  1. Asus F554LA-WS52 Disc Drive, Disc Drive: passo 1, immagine 1 di 2 Asus F554LA-WS52 Disc Drive, Disc Drive: passo 1, immagine 2 di 2
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Disc Drive: passo 2, immagine 1 di 3 Asus F554LA-WS52 Disc Drive: passo 2, immagine 2 di 3 Asus F554LA-WS52 Disc Drive: passo 2, immagine 3 di 3
    • With a plastic opening tool, gently lift and remove the back cover to expose the internal components.
    • (Not pictured) Remove the three cables attached to the keyboard and one touch-pad.
  3. Asus F554LA-WS52 Disc Drive: passo 3, immagine 1 di 2 Asus F554LA-WS52 Disc Drive: passo 3, immagine 2 di 2
    • Unscrew the three 5.7 mm hard drive-motherboard connection screws with a #0 Phillips head screwdriver.
    • Remove the small rectangular hard drive-motherboard connection board.
    • (Not pictured) Remove the hard drive.
  4. Asus F554LA-WS52 Disc Drive: passo 4, immagine 1 di 2 Asus F554LA-WS52 Disc Drive: passo 4, immagine 2 di 2
    • Unscrew the four 5.7 mm battery screws with a #0 Phillips head screwdriver.
    • Remove the battery.
  5. Asus F554LA-WS52 Disc Drive: passo 5, immagine 1 di 3 Asus F554LA-WS52 Disc Drive: passo 5, immagine 2 di 3 Asus F554LA-WS52 Disc Drive: passo 5, immagine 3 di 3
    • Unscrew the two 2.7 mm and one 5.7 mm CD drive screws with the Phillips #00 screwdriver.
    • With the plastic opening tool, gently pry the drive out from the metal brackets that hold it in place.
Conclusione
Altre 2 persone hanno completato questa guida.
Aaron Ratliff
Membro da: 10/09/18
527 Reputazione
4 Guide realizzate
USF Tampa, Team S1-G2, Leahy Fall 2018 Membro di USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 581
