Salta al contenuto principale
Asus EeeBook X205TA TrackPad Replacement
Cosa ti serve
  1. Asus EeeBook X205TA TrackPad Replacement, TrackPad: passo 1, immagine 1 di 2 Asus EeeBook X205TA TrackPad Replacement, TrackPad: passo 1, immagine 2 di 2
    • Remove ten Phillips #00 screws located on the bottom of the laptop:
    • Seven short screws.
    • Three long screws.
  2. Asus EeeBook X205TA TrackPad Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case (where the hinge is).
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA TrackPad Replacement: passo 3, immagine 1 di 2 Asus EeeBook X205TA TrackPad Replacement: passo 3, immagine 2 di 2
    • Using the 2mm Phillips Screwdriver, carefully unscrew the four screws holding the track pad.
    • Using the Phillips #00 Screwdriver, unscrew the three screws holding the track pad.
  4. Asus EeeBook X205TA TrackPad Replacement: passo 4, immagine 1 di 1
    • Unplug the ZIF connector
  5. Asus EeeBook X205TA TrackPad Replacement: passo 5, immagine 1 di 1
    • Carefully pull the track pad from the side
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 2-2, Sullivan Fall 2016 Membro di USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,819
