Salta al contenuto principale
Asus EeeBook X205TA Speakers Replacement
Cosa ti serve
  1. Asus EeeBook X205TA Speakers Replacement, Battery: passo 1, immagine 1 di 2 Asus EeeBook X205TA Speakers Replacement, Battery: passo 1, immagine 2 di 2
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Speakers Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Speakers Replacement: passo 3, immagine 1 di 2 Asus EeeBook X205TA Speakers Replacement: passo 3, immagine 2 di 2
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Speakers Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Speakers Replacement: passo 5, immagine 1 di 1
    • Carefully lift the battery out of the laptop.
  6. Asus EeeBook X205TA Speakers Replacement, Speakers: passo 6, immagine 1 di 1
    • Locate and lift the tabs from the LED/motherboard ribbon cable.
    • Remove the cable.
  7. Asus EeeBook X205TA Speakers Replacement: passo 7, immagine 1 di 1
    • Unplug the speaker cable from the motherboard.
  8. Asus EeeBook X205TA Speakers Replacement: passo 8, immagine 1 di 1
    • Pry the right speaker gently with the plastic opening tool.
  9. Asus EeeBook X205TA Speakers Replacement: passo 9, immagine 1 di 1
    • Pry the left speaker gently with the plastic opening tool.
Conclusione
IUPUI, Team S3-G4, Baechle Spring 2017 Membro di IUPUI, Team S3-G4, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G4
4 Membri
6 Guide realizzate
2 Commenti
Thank you very much for this detailed and helpful tutorial.
andrew - Replica
Thanks. You’ve helped make it clearer for me!
geometry dash
Martin Tolley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 891
