Salta al contenuto principale
Asus EeeBook X205TA Screen Assembly Replacement
Cosa ti serve
  1. Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: passo 1, immagine 1 di 2 Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: passo 1, immagine 2 di 2
    • Unscrew all 10 screws located on the bottom of the laptop using 2mm Phillips Screwdriver.
    • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
  2. Asus EeeBook X205TA Screen Assembly Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Screen Assembly Replacement: passo 3, immagine 1 di 3 Asus EeeBook X205TA Screen Assembly Replacement: passo 3, immagine 2 di 3 Asus EeeBook X205TA Screen Assembly Replacement: passo 3, immagine 3 di 3
    • Unscrew the four screws using Philips #2 screwdriver that connect the screen to the inside of the case for the laptop.
  4. Asus EeeBook X205TA Screen Assembly Replacement: passo 4, immagine 1 di 1
    • Unplug the No-Fuss Ribbon connector of the screen from the motherboard.
    • Carefully lift the screen away from the case.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 2-2, Sullivan Fall 2016 Membro di USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Membri
10 Guide realizzate
Un commento
What's that small black screen hanging out from the laptop
Tayler Grant - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,391
