Salta al contenuto principale
Asus EeeBook X205TA Battery Replacement
Cosa ti serve
  1. Asus EeeBook X205TA Battery Replacement, Battery: passo 1, immagine 1 di 2 Asus EeeBook X205TA Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Battery Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Battery Replacement: passo 3, immagine 1 di 2 Asus EeeBook X205TA Battery Replacement: passo 3, immagine 2 di 2
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Battery Replacement: passo 4, immagine 1 di 1
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Battery Replacement: passo 5, immagine 1 di 1
    • Carefully lift the battery out of the laptop.
Conclusione
Follow the guide in reverse order to reassemble the device.
Altre 8 persone hanno completato questa guida.
USF Tampa, Team 2-2, Sullivan Fall 2016 Membro di USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Membri
10 Guide realizzate
11 Commenti
By any chance , Can we run this laptop without battery ? I mean directly from AC ? Please suggest
Sourabh Verma - Replica
No, you must have the battery on.
Tayler Grant -
is this under warenty
bla bla - Replica
If you have one….
Tayler Grant -
My battery is stuck on orange led mode. My laptop cannot identify the battery….
Tayler Grant - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 82
Tutti i Tempi: 13,849
