Salta al contenuto principale
Asus EeeBook X205TA USB Port Replacement
Cosa ti serve
  1. Asus EeeBook X205TA  USB Port Replacement, USB Port: passo 1, immagine 1 di 2 Asus EeeBook X205TA  USB Port Replacement, USB Port: passo 1, immagine 2 di 2
    • Unscrew all 10 screws located on the bottom of the laptop using a Phillips #2 Screwdriver.
    • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
  2. Asus EeeBook X205TA  USB Port Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA  USB Port Replacement: passo 3, immagine 1 di 2 Asus EeeBook X205TA  USB Port Replacement: passo 3, immagine 2 di 2
    • The USB ports are located on the strip that looks like the motherboard on the left side of the laptop next to the battery.
    • Unscrew the four screws using Philips #2 screwdriver located around the edge of the USB ports.
    • Unplug the battery ZIF connector from the USB ports.
  4. Asus EeeBook X205TA  USB Port Replacement: passo 4, immagine 1 di 1
    • Carefully remove the USB ports from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 2-2, Sullivan Fall 2016 Membro di USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,512
